17.08.2016, 19:36 | #461 | |||
Звідки Ви: украина ивано-франковск
Авто: рено трафик
всем бусоводам привет помогите пробитьVIN VF1T1XF0512781772 не как не получается.
18.08.2016, 07:38 | #462 | |||
Звідки Ви: Закарпаття - Київ
Авто: Renault Trafic 2004, 1.9, 100
Parameter Value Title Trafic (from march 1989) T11F Glacier white bodywork paint Registration number WTM-K360 VIN VF1T1XF0512781772 Model Trafic (from march 1989) Model type T11F Date of manufacture 01 1995 Vehicle fabrication number C029142 Equipment level TOLE Paint code O389 Seat trim TMANCH Interior trim BLEVER Engine type J8S Engine fabrication number F941016 Gearbox fabrication number V008685 Number of gears 5 Axle type OT1 Body type Glazed Complete seat Separate seat Heated screen Yes Rear door opening 2 hinged doors Permanent link http://carinfo.kiev.ua/cars/vin/rena...heck?su=gamz8f Custom options Parameter Value VEHICLE WITHOUT RADIO REAR DOORS WITH WINDOWS FRONT 2-SEAT PASSENGER BENCH SEAT WITH FIXED SEATBACK TRACTION 800KG VAN TRACTION J8S ENGINE TRAFIC POWER ASSISTED STEERING DOCUMENTATION PHASE 3 WITHOUT FERRULE DOCUMENTATION PERIOD 1995 5-SPEED GEARBOX MANUAL GEARBOX COMPLETE PARTITION GLAZED FRONT SEAT LAP BELT FRONT SEAT BELTS WITH INERTIA REEL DEPOLLUTION STANDARD EU 95 DRIVER SEAT WITH THREE DIMENSIONAL ADJUSTMENT NO COUNTRY FEATURE INTERIOR STYLING BLUE GREEN SEAT UPHOLSTERY CLOTH MANDCHOU CLOTH OR PLUSH SEAT COVERING RIGHT-HAND SIDE DOOR SLIDING BUILT UP SPECIAL VEHICLE ORDER: WITHOUT SPECIAL VEHICLE ORDER WITHOUT LEFT-HAND SIDE DOOR COLD CLIMATE ROAD CONDITION: GOOD ROADS LEFT-HAND DRIVE SPECIFICATION COUNTRY: FEDERAL REPUBLIC OF GERMANY PANEL SIDE DOOR ADJUSTMENT OF HEADLIGHTS ON SITE TYRE SPEED CODE: PR6 TUBELESS TYRE DIMENSIONS: 175/14 80 MAKE OF TYRES: STANDARD TYRE GLACIER WHITE BODYWORK PAINT DIESEL MF ENGINE LEVEL SHORT CHASSIS NORMAL ROOF EQUIPMENT LEVEL: PANEL TOTAL LADEN WEIGHT 900 KG WITHOUT REMOTE CONTROL DOOR OPENING VAN DIRECTION INDICATORS WITHOUT SIDE REPEATERS System information Parameter Value Data language en Record was added in database 2016-08-17 21:16 Last query date 2016-08-18 08:37 Last update date 2016-08-17 21:16 Data display version 2.0 |
03.12.2016, 18:08 | #464 | |||
Звідки Ви: Минск
Заменил масло в кпп, поездил и обнаружил течь по штоку переключения передач, который сбоку. Течёт прилично, вся кпп в масле и немного на балке, заливал 2.7 литра нфп. Саун не забит т.к. долл туда ещё 200 грамм оставшихся. Прошу подсказать, возможно ли не снимая кпп поставить туда сальник, его размеры (купил 21/15/7.5 не уверен что подойдет), как выдавить фиксаторы рычажка (трубочка в трубочке пружинная ), можно ли подвинуть вовнутрь игольчатый подшипник чтобы поместился сальник?
04.12.2016, 08:41 | #465 | |||
Сальнік по розміру, але його туди не вставити. Так як місця для нього не залишається і запресовуеться він зсередини. Інша справа з верхнім штоком, тут таке діло пройшлоб. А боковий валік уплотняється манжетами, що знаходяться в самому підшипнику. Тому вскривати та міняти підшипник.
Походу, неможливо. |
Поблагодарили Eugene за это сообщение: |
Vychykau (04.12.2016)
04.12.2016, 09:17 | #466 | |||
Звідки Ви: Минск
04.12.2016, 09:44 | #467 | |||
От халепа: Мою писанину понимаешь отлично, или перевести? |
04.12.2016, 23:19 | #468 | |||
Звідки Ви: Минск
22.12.2016, 17:15 | #469 | |||
Звідки Ви: Луцк
Авто: виваро 2006 1.9 100-ка
Значить така хрінь.... машина 1.9 6ти ступка. почало машину піддьоргувати на старті, це продовжувалось десь з літа.. пару днав назад почали з трудом включатись передачі (недовключатись) , після цього в той же день завила коробка... пробувати розбирати чи зразу б\ушну купувати?
22.12.2016, 19:15 | #470 | |||
Авто: Opel Vivaro 2.0, 2008
08.04.2017, 21:18 | #472 | |||
Звідки Ви: Украина, Сумы
Добрый вечер. Подскажите в чем проблема? На второй, пятой и шестой передачах если ехать накатом и не жать на педаль газа, появляются какие-то посторонние шумы. Что-то чиркает как бы. Звук то сильнее то слабее. Машина рено трафик 2012. 2.0 DCI 6 ст. механика.
04.09.2017, 20:10 | #473 | |||
10.11.2017, 11:20 | #474 | |||
Звідки Ви: Украина, Одесса
Доброго времени суток.
Сделал капиталку двигателя. Мастер сказал, что выжимной и диск надо меня, корзину можно оставить. Так и сделали. После того как завели, было тарахчение. Выжимаю сцепление - тарахчение проходит. Без включенной передачи и в ходу при оборотах в 1,5т торохчение тоже проходит. Сначала думали что из за новых запчястей... Типо притирается... В педаль ничего не бьет. Передачи включались нормально, только олин раз получилось так, что 1 и задняя не хотели включаться с легкостью. Один раз, даже пришлось заглушить машину, включить заднюю, с выжитым сцеплением завестись и тронуться с места. Потом при переключении был хруст, после чего передачи включаются нормально. Проблема только в этом тарахчении. В пробке бывает что дергается. Масло в коробке менял. В одной из мастерской сказали что не тот диск сцепления. У меня Виваро 1.9 6-ти ступка. А диск брал в ржношном магазине от трафика. В другой мастерской сказали, что диск сцепления поставили задом на перед. В третей сказали, что вариант с неправильной установкой диска вполне допустим. У кого какие предположения что может быть. Понятное дело, что вскрытие покажет, но что бы подготовиться. просто ремонт начну в субботу вечером, а в воскресенье не будет возможности достать запчасти и день простою зря. |
01.01.2018, 20:21 | #475 | |||
Звідки Ви: estonia
Авто: RENAULT TRAFIC 2
Здравствуйте renault trafic 2,5 6 ступенчатая не включить 6 передачу троса работают но в самой коробке не переключить на коробке шток с тросом он сам болтается видать подшипники развалились .
27.01.2018, 15:13 | #476 | |||
Звідки Ви: Україна, Львів
Авто: Trafic 2.0 84kw 2012р
підкажіть хто знає, чи нормальні ці троси куліси Dura M610438
27.01.2018, 16:52 | #477 | |||
Звідки Ви: Украина Вишневое
Востаннє редагував oleg9489: 27.01.2018 о 16:58. |
02.03.2018, 17:39 | #478 | |||
всем привет. назрел вопрос, на который у меня нет конкретного ответа. и так, вводная: у клиента выварка 1,9 5ти ступка. притянули. в кпп клин. с эвакуатора снимали практически на руках. мотор запускается только при выжатом сцеплении. кулиса передачи включает, но реакции нет. вопрос в чем: клиент надыбал где то на западной кпп 6ти ступку с лагуны. продаван интересуется о наличии датчика в кпп. если покупать и переставлять, подойдёт ли она вместо 5ти ступки (шрусы, тросы кулисы, подушки, стартер, ) и тд. кто имеет опыт перестановки? подводные камни есть? заранее спасибо.
02.03.2018, 19:49 | #479 | |||
Звідки Ви: Тверь
Авто: Traffic 2008. 2.5
Тоже интересует этот вопрос, подходит ли коробка с лагуны на наши трахики. Моя гудит и чета кажется я на пороге грандиозного шухера.
02.03.2018, 20:10 | #480 | |||
но будет потеря из-за передаточних чисел хотя у тебя 2_5 должно бить более-мение ток там будет с 2,2 мотора с 1_9 тебе не прокатит
(Opel, Renault, Nissan) Куплю литые диски б/у на Виваро/Трафик/Примастар | Куплю... | |||
Хочу купить примастар, трафик или виваро. Бусоводы помогите? | Загальні технічні питання та тюнінг |
